QUOTE(bobcat229 @ May 3 2007, 03:58 PM)
I have a 2004 GX 470. I've seen some info on the net about overriding the Nav so that it can be used while driving. The instrutions mention going to the menu screen and the volume screen and toching the "soft" button. On my volume screen it just has the numbers. Anyone know if it is possible to override the Nav on this model?
Thanks.
I also have the 2004 Nav system
here is the trick.
turn the vehicle on and enter accept
go to menu
on the top right of the screen touch DVD, you will see the DVD NAV Disk info screen, you now touch the screen in the following sequence (just normally (not too slow but not fast, JUST NORMALLY)
Top Left Corner
Bottom Left Corner
Top Left Corner
Bottom Left Corner
Bottom Rightthen press and hold you finger on "override" until it UN-highlights, then select back and use as usual .
THIS WILL RESET AFTER VEHICLE IS TURNED OFF.
(There are no buttons in the corners, you just touch in the corner.)
