QUOTE(RAM MAN @ Mar 20 2005, 07:32 AM)
FranklinGonz, Sounds like your center differential lock is on. With the engine running push the button in front of the shifter it is the one just to the right of the 12v/120w power outlet. wait a few seconds and the light should turn off. Do not drive on dry pavement with the center differenal locked.
If the lights dont go out try backing up and driving foward a few feet as the four wheel drive system can get in a bind.
[right][snapback]117942[/snapback][/right]
Thanks, it's working like a charm, i look like a newbie on the GX the brakes are too sensitive in comparison to the 04' CR-V my mom has. What about the Rear Audio panel? i connected a Headphone and it doesn't work, do i have to configure it? The GX comes with the standard RDS audio system.
well now I inherited the 97' 4runner my dad had. it's SR5 pretty uncomfortable.
Oh forgot, where can i find a virtual owners manual in case it got lost, or something. :S
[right][snapback]118001[/snapback][/right]
did you check the remote if the rear audio to see if the "seal" is removed??? at first, take the remote out of the plastic, and go to where the battery is located and pull the tape out. That should make it work.
